SM465 to NP205 twin sticked adapter and crossmember options
TKnight
Active Member
Went out this weekend and tore up my 465-205 adapter. Looking at changing up the cross member as well while I'm under there replacing the adapter.. Curious what everyone is using for 205 crossmembers? Currently I'm running a beefed up cradle that was garage tabbed by the PO. Sticks down a good 4-6" under the frame. Wanting to be able to flat belly with a new cross member so looking for something that possibly uses the back bolts of the 205 to not hang as low as the current set up. Also I know AA makes the adapter from 465-205, curious if there's any others that may be a more popular choice. Any input would be appreciated. Thanks
It's the only pic I have.
2x2 running from one side of frame to the other. Then some rectangle welded beside it with holes in the bottom to get a socket in with bolts going up into adapter.
Brushing on the frame ends.
