P
If its free, its P
Comp ready , synthetic rope at a great price. These will get to you guys in the SE in 1-2days max shipping time ( and shipping is FREE )
http://www.4x4rockshop.com/scripts/prodList.asp
Part Number: SRC98281
* picture may not represent actual product *
Rated Line Pull: 8000Lbs (3630kgs) single-line
Motor: 5.5hp Series Wound
Control: Remote Switch, 12' (3.7m) lead
Gear Train: 3-Stage Planetary
Gear Ratio: 172.8:1
Clutch: Rotating Ring Gear
Brake: Automatic In-The-Drum
Drum Size: Diameter 2.5 (63.5mm) Length 8.75 (222mm)
Synthetic Rope: 94' 21/64" Diameter (28m, 8.2mm Diameter)
Battery Leads: 25mm2, 72(1.83m)
Finish: Black
Weight: 94.0Lbs (42.5Kgs)
Mounting bolt pattern: 10 x 4.50
The new Smittybilt XRC-8 Winch encompasses all the best features you would want in a winch. Every XRC-8 (8,000 LB.) winch features a 5.5HP Series Wound Motor and a Planetary Gear System with 172.8:1 gear ratio that will deliver power and reliability at a economical price. For a recovery system with the muscle and dependability to bail you out of any situation, the XRC-8 has all the heavy-duty toughness you're looking for. SYNTHETIC WINCH ROPE DSK-75 8,000lbs. 94ft.- 1/7th the Weight of Steel Cable - No Kinks, Curls or Wire Splinters to Deal With - Minimal Stretch â€" Non Rotational - UV & Abrasive Resistant. Specially coated to prevent slippage of the winch drum. - Comes with a protective sleeve to prevent overheating. XRC COMPETITION ALUMINUM FAIRLEAD - Manufactured from High-Grade Billet Aluminum material. - Protects your synthetic rope from excessive wear. Reduces binding and friction caused by angled pulls and will not fray or tangle your synthetic winch rope. Standard bolt pattern.
[attachment deleted by admin]
Gear Ratio: 172.8:1
Finish: Black
