Sold/Expired (SOLD) 88 cherokee trail rig
WHIZARD
Huntsville
SOLD.....................1988 Jeep Cherokee 4.0 with auto transmission, Jeep has two inch lift springs on front (I think) with 2 inch rough country spacer, Has add a leafs in the rear with a 3 inch rough country shackle.
33 /12.50 /15 Bias Ply TSL's on Soft 8 steel wheels. Tires have 95% tread left. No rock rash but some of the tread is cut and you can tell they have been on the rocks.
Dana 30 front with Locker
8.8 Ford Explorer Rear welded
ProComp tubular lower control arms, uppers have dowel pins welded in for extra strength. I put the jeep on its lid on the ledge at Summertown a couple years ago and have wheeled it maybe 5 times since. I bought a buggy not very long after the flop so I really don't need this thing anymore. It has no windshield and quite a bit of body damage but it has served as a good trail rig. I have an extra right front fender for the jeep that is straight that will go with it. I also have an extra set of wheels that you can have with it if you desire. They are not pretty but can serve as an extra set or something to mount a spare on. The roof was caved in some from the flop but I straightened it as much as I could at the time.
It needs an exo or internal cage, I never added one. I have a YJ factory cage that has extra bars welded in that you can have if you want it with the jeep. You could probably modify it some to put it in the jeep, it would be better than nothing.
$1300 Absolutely NO TRADES
Located in Huntsville, Alabama.
256-505-2104, leave message if no answer
Re: 88 cherokee trail rig
A few more.
You can see where I caved the roof in but straightened it some
Here is the YJ cage
