Sold/Expired SOLD**Built Full Width D60/D44 Combo**SOLD
calvinXJ
Selling the axles out from under my XJ.
D44 Front: Yukon 5.13s, Yukon chromoly inners/outers, Alloy USA Ujoints, Warn manual hubs, BTF high steer setup w/ GM 1 Ton TRE’s, Welded Diff, setup for radius arms-radius arms come with it.
D60 Rear: 5.13 Yukon Gears, Yukon Full Spool. Setup for leafs.
Comes with a set of stock spare shafts (inners and outers w/ ujoints in front, and one for either side in the rear)
Asking: $1500 OBO
Located in Hampton, GA
Re: Built Full Width D60/D44 Combo
Had a couple questions:
Front is Driver Drop. Has coil buckets. The radius arms are a custom weld-on job. It was originally set-up for leafs.
Drums in the rear. Internals were replaced new when I put it on my XJ.
Couple more pics
Are they set up for stock spring location? Did you use the factory steering box or hydro? How were the radius attached to the frame?
Yes, they're setup for stock spring location on an XJ. I originally ran my factory steering then went to a single ended ram. The axle and tie rod have got the brackets for it. It attached to the frame at my custom crossmember with some brackets welded on. I'll get some pics up tomorrow.
Okay that would be great. These would be great under the XJ hanging from Trey's backhoe in my avatar.
Yes they would. Wouldn't take much to get em under there either
