Sold/Expired SOLD...Crawler/Buggy
DS13
Member
**NEW MODIFICATIONS, NEW SKINS,
NEW ALUMINUM TOP, NEW PAINT,
And NEW REBUILT TRANSMISSION WITH NO RIDES***......NEED GONE!!!
DRIVETRAIN-
1.6 liter 8 valve Tracker motor (pulled from tracker at 60k miles)
3spd Auto with shift kit
T25 Turbo, Tial Blowoff valve.
200 mixer with model E evaporator
Aluminum intercooler and oversized aluminum radiator all with SPAL electric fans.
Finned aluminum trans cooler.
Stainless turbo manifold, intercooler piping, and exhaust.
MSD Rev limiter
6.5 geared samurai case with spine and chromo front output.
Stainless Steel drive shafts with Creeper Joints
Chevy 1 wire alternator.
Steering
PSC resivoir and high flow pump.
Trail Gear double ended ram, aluminum tie rods with chromo ¾'' heims
All new hoses
-AXLES-
Toyota trussed solid front axle. High Pinion 4.10 third, longfield axles, drive flanges, ARP studs,
Six shooter knuckles, SS braided brake lines.
IFS rear axle, disc brakes with GM calipers, 4.10 v6 third with spool.
Suspension
Four linked front and rear.
117" Wheelbase, 19.5" belly on 37's
2.25'' 7075 Aluminum lower links with 1.25'' heims
1.5'' 6061 Aluminum upper links with ¾''heims.
14'' Sway-a-way coilovers front
16'' Sway-a-way coilovers rear
Rear Currie Antirock sway bar with aluminum arms.
Wheels and Tires
5x 17x9" Forged Aluminum ATX Slabs
4x 37'' BFG Red label Krawlers
MISC.
Ramsey 5000# short drum winch with synthetic line.
Optima Red top battery.
1/8'' Aluminum hood and roof panels.
Two aluminum propane tanks.
7'' LED headlights
3/8'' Aluminum belly pan with ¾" UHMW and SS fasteners.
G-Force Camlock harnesses.
1-Quick disconnect fire extinquishers
$12,000
"Need Gone ASAP".....located in Gadsden Alabama
Call or text 256-509-9911
Thanks Drew
Yes it will accommodate a big guy I'm 5'10"
285 the guy I purchased it from that built it was 6'4-6'5 and probably 250lbs
