Sold/Expired SOLD DELETE THANKS HARDLINE
Debo
89 22re w/887 miles on new reb.
Block stripped, hot tanked, new, freeze plugs, bored 60 over, align bored, forged pistons, rods checked for size&roundness, recon one rod, replaced wrist pin bushings, honed and fitted. Polished crank w / new pilot bushing. Master reb kit w / HD timing chain w / steel guides.Proper break in with break in oil. Currently running full syn 10w30. Egnbldr RV head filled with erson cam.218 / 218@. 50 rpm range 2000-5000. LCE seal saver , and rear main seal. New Raptor 4-hole high spray injectors.Cold air intake. Backed by W56 5spd AISIN 1200 ft-lb clutch, Marlin Crawler doubler, stock 2.28 both cases, TG twin stick back case.Front Range x-member w / skid plate. All work on trans and duals done by previous owner w / supposed 1000 miles. New clutch master.
Going to 4.3 swap or om617 swap depends on what moves. Asking $ 2500 for motor, trans,duals and x-member or $1500 motor, $1000 trans ,clutch ,duals x-member. Call or text 54zero -8seven5-eight 4 three 9
Re: Built 22re 887 miles w/ w56 and duals
TTT
Bump
whats ur location? or did I miss it?
Located in Huddleston Va
TTT
Bump
Bump
$2000 for combo, same price just motor includes ecm and efi harness exhaust to if wanted, $500 for trans, doubler and x-member.
Re: Built 22re 887 miles w/ w56 and duals PRICE DROP
TTT
Bump
Deposit made sale pending
