Sold/Expired SOLD! GM Ram Jet 350 crate engine
yankster
Gibson, PA
I'm doing an LS upgrade on White Trash so the Ram Jet is for sale.
Rated at 350 hp and 400 ft/lbs of torque. They always dyno at 370-375 hp.
Vortec heads
MEFI 4 controller and harness
Fuel pressure regulator built into the rails.
Ceramic coated shorty headers
Synthetic oil since new
This engine is in perfect running condition. No leaks. No burning oil.
In the last year I've added or replaced:
Texture black valve covers
New computer and harness from GM
New GM air filter
New ignition module
Accel ceramic high-heat plug wires.
New starter
Just needs pulleys and belts to run.
Connect a constant 12v, switched 12v, fuel pump wires and ground to run. Very simple to hook up.
I have the install manual, service manual and code reader I will mail to the buyer
Get a fuel injected engine for the price of aftermarket fuel injection!!
$2450 or make reasonable offer
Located at CSC Fab's shop
396 Mills Rd. SW
Cave Spring, GA 30124
(706) 777-0596
Re: GM Ram Jet 350 crate engine
Nice motor wish I had the money. I've always liked the simplicity of ram jets. Did you have any issues using it off-road? I seen in an earlier post you said you would like more power. Is that only reason for selling?
Your hydro steering lines look thinner than most are they braided?
Free bump. Glws
Free bump. Glws
Yea more power was the only goal. The engine itself works flawless. Never overheats or stalls, and is pretty fuel efficient. I ran all day on 7 gallons.
This would be great in a street vehicle if no one wants it for a buggy.
The steering lines are small. All that is being upgraded now with rear steer being added as well.
I saw this motor in the old red Csc buggy, worked great and 350hp seems like a modest rating , it's ripped the tires pretty good , glws :dblthumb:
No dyno tuning
No computer flashing
No harness mods
Just hook it up and go! :driving:
