Sold/Expired SOLD PLEASE DELETE
iluv4nick8n
London Ky
Trail Gear Rock Assault Toyota front end housing. Axle tubes are 5/16" thick 1020 DOM tubing with an outer diameter of 3". The short side of the axle tube has been lengthened by 3", making the axle IFS width, so there is no need to run wheel spacers. Center section is press formed 1/4" plate steel and bottom is shaved to give 3/4" more ground clearance under the diff. The third member mounting surface is 1/2" plate steel. Has all TG 3 link brackets and TG shock brackets welded on, TG diff stud eliminator kit, TG breather, and Marlin Crawler seals. 30 spline cromoly axles that fit the housing width, and TG 1.25" creeper joints. 3 left hand and 3 right with 2" x .250 DOM tubing for lower and upper links. The Panhard bar is 1.25" x .250" wall DOM bent to clear v6 oil pan. Was all bought as a complete TG front 3 link kit, needs ram mounts cleaned off. SOLD for everything. London Ky Text is fastest 606-231-2722
Re: Trail Gear Rock Assault front housing, cromoly axles, link bars
Are you willing to split? If so how much for the links and how long are they
Hate to split it up, but I will if someone wants the housing and axles without the link bars
How much for the housing and the shafts?
Guy is on his way to pick up the housing and axles. Lower links measure 48.5", top is 34.5" with joints screwed all the way in. Joints have 2.5" of thread. Panhard is 31.5" and bent to clear 3.4 oil pan. Asking $200 for all links and joints
