1987 Suzuki Samauri
SOLD
1.6 - 8v engine from a 1993 Tracker, less than 100k
Weber two barrel carb
Header
Sami 5 speed
4.1 gears in t-case
4.88 gears with spools in both axles
34 X 10.50 – 15 LTB’s, DIY bead locks on 8 inch wheels
Wheel base is 85.5 inches
Weight is 2,320# with winch and tools LIGHT IS RIGHT !
Disc brakes all around
Spring over axle lift
Fiberglass seats
Tool / spare parts box in the rear with a place for your cooler too!
Front axles, heavy duty chromoly
Over the top steering with power steering
Front axle housing is trussed
Rear axle house is Hybrid heavy duty from Sky Manufacturing using Chevy Tracker 8 inch gears
Rear drive shaft is Toyota
Winch, (Warn 8,000#), and battery both mounted low in the rear for better weight distribution
Hi-Lift jack mounted on cage
Some spare parts: chromoly shafts and birfield, drive shafts, complete new, still in the box front knuckle rebuilt kit with bearings, misc hubs, bearings, seals, etc
Price Reduced to $3,200..............time for it to go!
PRICE DROP TO $2,800................
Located in northern Michigan, Interlochen to be exact !
SOLD
Header
Sami 5 speed
4.1 gears in t-case
Fiberglass seats
