Sold/Expired SOLD!!!! Thanks Hardline!
scooter60
I have a few items for a Toyota 1 -ton swap project. I recently swapped my leaf springs for some churched up air shocks and have some stuff that someone else may need.
Sold!!!!!!!First is a Dana 60 pinion to Toyota driveshaft flange. It has both toyota bolt pattens and will not include the bolts. These are $110 from high angle and $89 from Sky Manufacturing. I am asking SOLD.
SOLD. Next is a set of Sky Manufacturing toyota full width swap front spring shackles. These are needed when swapping a full width Dana 44 or Dana 60 under a 83-95 toyota. This moves the springs out to the factory spring pads of the Dana axles. Sold, Sold, Sold, Sold
I also have a set of mild steel leaf spring plates for a GM Dana60 from Barnes. I am asking $25 shipped for these. SOLD SOLD SOLD
All parts are located in Mt. Washington, Ky. Call or text at 502-644-5412. If no answer, please leave a message.
Sent from my SPH-L720T using Tapatalk
Re: Toyota 1-ton swap parts
Shackles are sold. Thanks Hardline.
If you buy something from this guy and your not happy I'll give you your money back! Cool dude! :****:
Spring plates are sold. I still have the Dana 60 flange. $70 shipped.
Re: Toyota driveshaft to Dana 60 flange
Excuse my ignorance.....this works on HP or LP 60?
Should.....I believe it is 29 spline. I had it on a low pinion but I think they are the same spline from low to high pinion. I'm sure there is someone on here that knows fo sho.
I still have this. No one putting tons under Toyota's anymore?
