Ghost
iCrawl
I've had this one for almost a year now (which could be a record for me). I love to change things up and I believe it's time. If you are looking for a smaller, lightweight, crawling rig don't let this one pass you by. This is turnkey rig and ready to hit the trails today. I've had some fun in this one for sure. It is very clean and just a simple buggy.
Specs:
Buggy is powered by a 96 sidekick 1.6 16 valve fuel injected motor that runs with the help of Trail tuff wiring. The motor has a Ring R adapter to W56 Toyota trans. It has Toyota dual cases with stock 2.28 gears in the front case and Trail-Gear 4.7 gears in the rear case. Also has TG twin sticks and Longfield output. The front drive shaft is new.
Built from 1.75"x.120" DOM with 2"x.185" square sliders with .5" round bar. Buggy weighs in around 2800lbs. Flat belly with 5051 1/4" for the skid. Also has 5051 3/16" roof panel.
Front axle is pass drop waggy D44 with new 4.10 R&P and a Detroit, Alloy inners, CTM joints, Nitro outers with slugs, HD fabbed knuckles and arms.
Rear axle is a Toyota with a 4.10 gear that is spooled with TG cover and disc brakes.
Full hydraulic steering with PSE double ended ram, new TG pump, Howe reservoir with filter and alum heat-sink cooler.
Front suspension is 3 linked with 2"x.250" chromoly lowers. The rear is a double wishbone. It has Hybred 16" Rock Equipment air shocks on all 4 corners with 2 Bilstein 4" bumps in the front. Limit straps on all 4 shocks also.
37" maxxis trepadors (sticky) mounted on alum allied beadlocks with steel rings (and yes I like to run the backwards), new corbeau seats with new RJS harnesses, 10 gal fuel cell, aluminum radiator & shroud in the rear, 12 volt guy switch panel, rock lights front and rear, 8000lb winch with new synthetic line, alum fairlead. All controlled with dash switch.
Spare parts that will come with the buggy, full set of stock front axle shafts with joints, pair of slugs, front and rear drive shafts, Toyota 3rd member with 4:10 gears, rear axle shaft, extra hood, plus some misc stuff.
Contact info and price:
Jason
Call or text: 601.4one6.047one
Richland, MS (just 5 mins south of Jackson)
Price: $12,000
Trades – the only trade I would be interested in is a TJ
Specs:
Jason
Price: $12,000
