COLT
I'm on a boat.
I have a 38' toy hauler I am going to sell. I am out of the Crawling game for a while and it is taking up real estate in my back yard.. I don't need to sell it as it is not costing me anything. I just don't use it anymore and probably will not be for the next couple years.
YES!!! This camper has enough room for a four seat Crawler and a RZR XP with room to spare. To put it into perspective.....You could load a 4 door longbed truck on the back of this hauler and still put a RZR in front of it! It pulls awesome and stops well under its own power. This is a home built camper, so you would have to register it for your tag as such..
Specs..
length is 38 feet
Bulldog Brand Gooseneck
3 axles all 8 lug heavy duty
New tires
New Bearings
Brakes on all 3 axles
New 13,500 BTU Roof Mount air conditioner
New Insulation (this thing will freeze you out!)
New Fridge
New Microwave
New Double Burner Hot Plate for Cooking
New TV/DVD combo Flat panel LCD TV
New sofa that turns into a bed
New Queen Mattress in the tongue
Newly wired for 110 with breakers and receptacles throughout
New floor
New tail Lights
I put a lot of work into this things, and it still needs a little more. It needs to have the wood-tile flooring put down inside, and the walls need to be pulled out of the inside and replaced with a better material. It is ready to camp or haul right now, but these are just a few things that need to be fixed. I have not replaced the clearance lights on it yet either. The camper will run on relatively low power. I figure a 3500 watt generator will run the whole thing. I plug it into a 20 amp receptacle and it has no problem.
My BOTTOM DOLLAR is 5K.. Priced to sell quick and easy without any back and forth!
Located in Pensacola Fl.
Call me at 850-791-4149
Colt Nowlin
Specs..
length is 38 feet
New tires
New Bearings
New Fridge
New Microwave
New floor
New tail Lights
Colt Nowlin
