Sold/Expired sold
Minizilla
Member
Arkansas/Oklahoma
93 Toyota Truggy full exo cage and back halfed, 3 link front and triangulated 4 link rear brand new fox 2" coil overs, 16" travel
TBI 350 with the heads decked and shaved 202/160 valves dual spring, bored .030 over and v8 conversion headers
TH 350 with advanced adapters 350 to toyota t-case
Dual Toyota t-cases 2.28 doubler with 4.7 kit in rear case ( also have a 203/205 setup to replace yota cases with, 203/205 I have bought the rebuild kits and the female input conversion for the 205... all you need to do is buy the doubler to put the 203/205 together also have the adapter from 350 to 203 for the trans)
Dual steering rockwells ( completely rebuilt) rear is welded and front is an open diff and driveshaft brakes , with full hydraulic PSC steering front and rear (All Brand New)
almost new 44" TSLs with single bead lock wheels
Rear mounted radiator with dual 10" fans and fan shroud from BE COOL radiators
18 Gallon fuel cell
Interior
Sheet metal Dash
Corbeau Baja SS seats (brand new) 4 pt harnesses
Auto Meter gauges
cd player
cb
B&M Shifter
Just so we are clear, the rear output shaft in the transfer case is currently broke, I have to take it apart to send the shaft back to Longfield Axle so they can replace the 300m shaft this is the reason for the 203/205 being included..... The yota cases, though built as much as they can be, cannot hold up to the v8 power and rockwell gearing
I just had this rig built over the winter and just got it back about 3 weeks before the Hog Wild Shootout, the HWS was its shake down run, there are some things that still need to be tweaked.....
It needs bump stops for the rear axle
One of the bump stops for the front axle needs to be lowered a bit more
The power steering pump needs to be tweaked more to allow for faster steering
Right now all it needs to be back to wheelin, is the rear output shaft in the t-case..
I dont have to sell, but I dont want it to sit and rust either..... Im needing more of a dual purpose rig...
Price is $18,000 OBO price is negotiable call or text 479-438-3335 located in Beebe, AR north of Little Rock approximately 20 minutes...
Consider trade for a nice Rubicon or partial trade for mild built TJ w/4.0 or RZR, Camo Ranger
Re: 93 Toyota Truggy Rockwells and 44s
Any pics of the inside and the motor???
