Sold/Expired SOLD
Steele3
Lutts, TN 38471
---SOLD.
72 GMC 4x4 LWB, 350/4speed/205 gear drive t-case. GOOD ***LE. Truck is running/driving but does need some work. Motor has a little smoke, but seems strong, it had old gas in it when I got it but I have been running fresh gas throught it and its getting better the more it runs. It could use a set of plugs when it clears up more, I put some in it and got it running better but still seems to miss at times. Truck will quarter crank when warm and idels good. Has a miss when you get on it, i think its fouled the plugs again. They were bad when i first got it running, it ran good for a while now its missing again.
It has rust in the rockers and cab corners, its had a rocker put on the pass. side at some point, and on the driver side also, but the driver side was riveted and its come loose. Pass side of the bed is rusty where side mees the floor in inside of the bed. Its in pretty good shape most everywhere else for its age. Tailgate is in ruff shape and bent, the windsheild is cracked, but other glass is good. Frame is in good shape, I have not found any rusted through places.
I have a good ***le, but I think someone put a 4wd frame under a 2wd body, glove box says nothing about 4x4, but dose call for an auto trans., frame is correct for truck though, its not a later frame best I can tell.
$1200 might trade but rather have cash.
Located in Lutts, TN txt/call 931--3o6-==158O
Re: 72' GMC 4x4 lwb - $2000
Bump for lowered price. Would like to move this so hit me up if your interested.
Would take partial trades on 39-38" tires, air shocks 2.5" in 14"s, GM auto trans w/205, 205twinstick, decent stand up tool box for shop nothing fancy
