Sold/Expired Sold
TBItoy
532
Dodson Branch, TN
Stock 4.88 gears.
No carrier! Ready for the locker of your choice.
$80 shipped.
$50 picked up
I used the factory open carrier in a high pinion front diffs is the reason it is missing, everything is in good shape, all ring gear bolts, lock tabs, etc is there,
Re: 4.88 and 4.56 Toyota v6 3rds
Is this a set of each or one 4.88. & one 4.56 just got a dual cases w/4.70s and think bout stepping down ain axle gears
One of each.
Tech tip of the day: factory 4.88 3rds can only use factory 4.88 toyota gears, because the pinion offset is different than every other toyota 3rd. Instead of having a carrier break like Dana axles, toyota cast an entirely different 3rd for their 4.88 gears.
Factory 4.88 gears are pretty common in 90s 4runners
I will install new spools for $325 shipped for a complete diff.
Will you be at RBD this year? If so, how much for both if picked up there?
Re: Re: Re: 4.88 and 4.56 Toyota v6 3rds
Nope not this year, I'll most likely be in the shop putting in a replacement motor
