nealcj8
I'm thinking about making some changes so I thought I would throw this out there. I built this buggy a little over a year ago, it has probably ten or so rides on it.
Engine: 6.0 LS 2 MEFI computer and harness, Bosch 36 lb injectors 90 mm cable throttle body. I have the receipt where it was purchased new, this is not a junkyard pull out or a rebuilt motor.
gauges: Racepack
Transmission: TH350 reverse manual valve body, winters shifter, and cooler with fan mounted on it.
Transfer case: Atlas 3.0
Front axle: dodge 60 35 spline chromo inner and outers CTM joints 5.38 gears Detroit Reid knuckles dynatrac stub hub kit and lock out hubs
Rear axle: Dana 60 5.38 gears Detroit 35 spline chromo shafts
Wheelbase is 116", belly hight 25", top of the cage is 74"
Fox 12 inch coilovers, all PSE steering, corbau seats, 2 in Crow harnesses, 17 inch monster beadlocks with 42 Irok stickies, brand new yellotop optima, summit brand heater. Two piece front driveshaft with wideopen design carrier bearing, new front brake pads and calipers. I have the software and cable to tune the engine and a whole folder of recites of most everything when the buggy was built. I'm sure there is more that I forgetting. $27,000 or I might do some trading on a LJ or Tj with tons and cash my way 256-762-6478
gauges: Racepack
