sastoy
I've got a 1994 regular cab toyota for sale.
Drivetrain:
22re, w-56, duals w/4.7 in the rear case
Front Axle:
Hybrid FJ 60 9.5 third with FJ 80 outers, build to factory width (63.5") to use stock shafts. Trail gear chromo inners and outers w/ drive flanges.
Full hydro steering with Surplus Center dual ended 8" ram with factory low steer arms RHD arm on pass side and ARP knuckle and hub studs. Welded 4.10
Rear Axle:
Factory FF FJ 80 rear, 9.5 third. (63.5") disk brakes, 4.10 welded have ARP hubs studs as well, not installed
Suspension:
Front is dual triangulated 4 link, 7/8 heims and 2" aluminum links. Radflo 16" 2.0 air shocks, valved 45/85 with 360 ml of oil. Radflo 2" travel 2.0 air bumps.
Rear is F-150 leaves inboarded 1.5" W/ Fox remote reservoir shocks
Wheels/tires:
40/13.50/17 Maxxis Creepy Crawler Stickys on 17x9 Trail Ready steel beadlocks w/ aluminum rings. Tires are about 80%
Other:
Full cage W/ 5 point harnesses and suspension seats
Full PSC steering kit, pump, reservoir, and orbital
Warn m 8000 W/ masterpull rope
On board air w/ tank and a mount for c02 tank
Action packer and Artec quart crate
Aluminum fuel cell w/ storage rack above it
LED rock lights
Throwin in a new 24" LED light bar cause the headlights suck
Trail gear bomb proof motor mounts
1/4 wall driveshafts front and rear
Full set of spare shafts front and rear
39.5 Irock on 16 steel wheel
Have both doors, another set of fenders, hood, cowl, and rear glass and plexi
$ 11,500 OBO located in Ooltewah, TN
Drivetrain:
Front Axle:
Rear Axle:
Suspension:
Wheels/tires:
Other:
LED rock lights
