Sold/Expired Sold
Mooretoyx4
For Sale is an AA toy gear case to 300/atlas adapter. The toy case is included already assembled. This will allow you to run a toy/dana300 or atlas doubler on your Toyota 5 speed trans. I re drilled the adapter to rotate the 300 flat but my drill press didn't drill the holes straight. It does not effect the holes that already came drilled in the adapter. It could also be fixed. I am only selling because I am going to an auto. $600 shipped from Indiana to the lower 48.
http://www.advanceadapters.com/products/50-5915--toyota-truck-gear-reduction-housing-to-the-jeep-dana-300--atlas-transfer-cases/
The w56 and 3rz bellhousing are also available for sale.
Re: Toy to dana300/atlas adapter
Is there anyway possible to run this without the crawl box?
The kit has to use the crawl box. It comes with a 23 spline output to adapt to the 300. The adapter bolts to a cover that completes the toy case. If that makes sense.
So why wouldn't this work with an auto if it is a crawl box to tcase adapter?
Just curious for my own knowledge. We talked about running a setup like this on mine at one time.
Don't mean to clog up your for sale ad with questions
Stuntman Autoworks said:
I already have a crawl box though so I just need the adapter
I gotcha but there is more to it than just the adapter. I'd have to take the case all apart then you'd have to tear your case apart and put it back together. It's easier to sell/buy the whole thing.
It would work. I'm using a V6 auto trans so I'd have to buy an adapter to a gear case but would work fine on an already gear driven auto trans.
10-4, that's what I was thinking
you don't wanna end up running multiple adapters, totally understand
There is no Toyota auto trans that uses a gear drive case. It would be an auto trans with adapter to 4cyl gear drive case.
Thanks, shows you how much I know about autos haha
