crawler1
1988 Cherokee long arm suspension with jks adjustable coil spacers the suspension is sitting about 7.5" right now.
Dana 30 front with locker and 4.10 gears and new Yukon chromoly single piece axle shafts with Spicer u joints with new hub assemblys axle seals and pinion bearings,Over knuckle steering with heims, sway bar disconnects, slip yoke eliminator. Ford 8.8 rear end swap,with locker and 31 spline shafts and iron rock offroad truss. Aftermarket front and rear bumpers with 35x14.50x15 tsl swampers mounted on 15x10 steel wheels. Jeep has power windows and seats, no carpet. Heat works but no a/c. Drives and runs good. Clean ***le in hand.Not gonna be a daily driver but will be a good trail rig. I'm sure there is stuff I am forgetting $3500 *winch and light bar can be negotiated if not will be removed*
southern il . $ 3500 618-926-5978
