ECGS
Fully custom built front Ford SuperDuty ball joint Dana 60 front narrowed to 63.5" wms. Setup for 8x6.5 bolt pattern, complete hub to hub specs follow:
DANA 60 FRONT AXLE ASSEMBLY
CHOOSE GEAR RATIO: D60R-513
ADD 35 SPLINE CHROMOLY SHAFTS: 35 Spline Inners/Outers (4340)
ADD DIFF COVER: ARB
LOCKING HUB STYLE: YUKON 35 SPLINE HARDCORE HUBS
SELECT LUG PATTERN: 8X6.5
SELECT STEERING: TIEROD/DRAGLINK-HIGH
ADD TRACKBAR: No Trackbar
SELECT CARRIER/ TRACTION: ARB RD167
YOKE STYLE: 1350- UBOLT STYLE
NO BRACKETS************
WMS: 63.5"
Matching Full Float disc brake Dana 60 rear, matching 63.5" wms. Also 8x6.5 bolt pattern, also complete from rotor to rotor. Setup with Ford factory style rear disc with internal parking brake drums. Specs Follow:
DANA 60 REAR AXLE ASSEMBLY (FULL FLOAT 8X6.5)
ADD E-BRAKE CABLES: Both E-Brake Cables
FINISH: Flat Black
CHOOSE TRACTION TYPE: ARB - RD166/RD167
CHOOSE DIFF COVER: ARB COVER
CHOOSE GEAR RATIO: D60-5.13
SELECT YOKE: YOKE-D60-1410-U
UPGRADE DISC BRAKES: Disc Brake
FULL FLOAT REAR-8X6.5
WMS: 63.5"
Where to be setup under a TJ based buggy with links and coilovers. Due to a life changing event the customer was unable to pick them up upon completion. They are complete ready to ship with a 5 year warranty!!!
Price is $11,000 Shipped OBO
