Sold/Expired Spidertrax Unit Bearings & Brake Hats
InDaShop
Dont Tread On Me
Sugar Land
4 Spidertrax 6x5.5lug 35spline unit bearings NEVER RAN!!!
From their website:
http://www.spidertrax.com/s.nl/it.A/id.2192/.f
Spidertrax upgraded F450 Ford 1 ton unit bearings are the answer to ultimate rock crawling performance. We start with the actual, made in USA, OEM unit bearing used by Ford which is without question the best unit bearing on the market. Then, we CNC machine each one in-house to accommodate upgraded 35 spline stub shafts and a 6 x 5.5" wheel bolt pattern complete with 1/2" screw in wheel studs. Designed to work with Spidertrax Ultimate 60 Knuckles or other aftermarket knuckles using F450 style unit bearings. Do not be fooled by cheap imported immitations!
Weight: 20 lbs.
Part #: FUB-6512
New Price: $369.95
2 are shelf only and were for my rear axle so they "do not" have the inner support bearing SCE2414(they are $6-8 online) if you plan to use these on a steering axle.
$320 each/shipping included.
2 have been bolted to the car for mockup only and have had lugnuts on them. These were for my frontend and "do" have the inner support bearing.
Close up of inner bearing needed for the front two of the above pics if running on a steering axle.
4 Spidertrax 5 or 6 lug disc brake hats NEVER RAN!!!
From their website:
http://www.spidertrax.com/s.nl/it.A/id.2318/.f
5 & 6 Lug Hat
Manufactured from billet 6061T6 aluminum, the Spidertrax Aluminum Hat packs incredible strength at an impressive weight of under 2 lbs. Designed specifically for rock crawling, you will no longer have to retro fit other manufactures hats to work with your bolt pattern. All hats are anodized in dark blue, using an anodizing process for double corrosion resistance. Designed exclusively for use with Spidertrax Rotors.
Weight: 2.53 lbs.
Part #: HAT-5
New Price: $99.95
You can also run a Tubeworks rotor if you order it with the Spidertrax pattern. Just an FYI.
Two have only been out of the box for this pic the other two were used in frontend mockup and do have some cosmetic scratches on the wheel mounting surface.
SOLD shipped for the never used two
SOLD shipped for the two used for mockup
Why am I selling??? I upgraded to Spidertrax Prohubs, my loss your gain.
Send me a PM,
Wyatt
B Gillespie said:
Pro hubs? Can't hide money!
If these were 5/5.5, they would be in my garage.
They can easily be redrilled to 5x5.5 I have a guy that can do them, but might as well buy them new that way since these are new.
Yeah, agreed. I just need a few spares; nothing wrong with the Currie hubs on it now.
