Rock Crawling Forums
spool locker question ?
Reply to thread
Message
<blockquote data-quote="Just Differentials" data-source="post: 1270013" data-attributes="member: 18343"><p>Doesnt quite work like that. Althought the solid spacers are better, the crush sleeve wont just fail. It is between two bearings that are both set against steps, so it cant really collapse on its own. I have seen TONS of failed toyota diffs as a result of spun bearings. When the carrier bearings dont fit tight, they will spin under load, especially on the ring gear side. This loosens the carrier bearing preload. Under load the pinion will deflect the ring gear, the looser the carrier the more deflection and the more likely to snap teeth. More often than not when disssassembling a 3rd member with broken gears you will find loose preload on the carrier, either not set tight enough from the get go, or spun bearing. This is based off of actually doing and seeing thousands of them.</p></blockquote><p></p>
[QUOTE="Just Differentials, post: 1270013, member: 18343"] Doesnt quite work like that. Althought the solid spacers are better, the crush sleeve wont just fail. It is between two bearings that are both set against steps, so it cant really collapse on its own. I have seen TONS of failed toyota diffs as a result of spun bearings. When the carrier bearings dont fit tight, they will spin under load, especially on the ring gear side. This loosens the carrier bearing preload. Under load the pinion will deflect the ring gear, the looser the carrier the more deflection and the more likely to snap teeth. More often than not when disssassembling a 3rd member with broken gears you will find loose preload on the carrier, either not set tight enough from the get go, or spun bearing. This is based off of actually doing and seeing thousands of them. [/QUOTE]
Verification
Post reply
Latest: Sawzall
58 minutes ago
Daves Offroad Supply
Latest: Daves Offroad Supply
Wednesday at 10:52 AM
Vendors
B
Latest: Bebop
Tuesday at 7:19 PM
P
YouTube of the day
Latest: paradisepwoffrd
Monday at 8:21 AM
Cash LeCroy Illness
