Sold/Expired Steering 70HD
51Jeepwillys
Sanger, TX
Plans have changed and gonna try and sell the steering 70HD i started building. It has link tabs on it that just need to be drilled out to whatever bolt you want to run. Still needs the custom shafts made for the inner axles. Branik Motorsports will make them for $225 a shaft. You can run ford or chevy outers. If you run chevy drw hub the WMS will be 76.5". You will need the knuckles out of your choice for this axle. Basically all ive got is the housing with a carrier and i think 3.73 gears. Will take $200 for it. It located in Sanger, Tx. Im gathering parts to build a single seater so i would swap it for anything i may need for it. If your interested send me a PM and ill send you my cell number. Here is a link to the build thread on it and a pic of it. If it doesn't sell then ill eventually finish it and stick it in the back of the buggy. I can probably get it to TN pretty easily. Got a buddy that goes up there a lot.
70HD rear steer axle
