Stumps
Member
2010 built buggy.
108" wheel base, 84" wide
Buggy info:
5.3 with Jim's tune - LS1 intake(backwards) - Moroso LS1 oilpain with baffles and remote oil filter re-locator
th 400 - art car shifter - deep pan
Chevy 60 front with 5.13 and RCV's and Yukon Grizzle- gone through around Sept. 2012 RCVs, seals, bearings, kingpins, etc. were all replaced
front is fully trussed with ORC
PSC full hydro with double ended ram
Solid 3/8" thick diff cover
D70 rear 5.13 with Detroit - BTF truss and diff cover, disc brakes
Yukon 35 splined rear axles
Drive Shafts w/1350 u-joint
Atlas 4 speed 10:1 with heavy duty outputs
dual willwood master cylinders and pedals (one front, one rear)
16 gallon fuel cell
HID head lights
BFG Krawlers with about 90% tread
Trailready Beadlocks
Corbeau seats (New)
Corbeau 5pt harnesses (New)
2.5" x 16" travel Fox
2" aluminum links with all 1.25" QA-1 hiems
Warn 9.0 RC
Magnaflow muffler
LED tail lights with working brake lights
TJ Hood and Grille narrowed 6.5"
FOA 2.5" bumps up front
LED tail lights with Painless brake light switch
Rigid 40" light bar
Rigid rock lights front and back
Spares:
39" Krawler (60%) mounted on TrailReady Beadlock
35 Spline 4130 rear axles (new)
RCV 35 spline inner and outer axles (new) complete set
RCV driver side axles (inner and outer shafts) (used with 10 degree of twist)
Spare comp synthetic winch line (comp)
Spare skins
Material to make another set of skins
Spare tire rack to carry spare and high lift jack on trailer
Power Tank N2 tank,gauges and hoses for adjusting shocks and bump stops
Power Tank CO2 tank with gauges and hoses
Spare front and rear drive shafts w/1350's (both new)
$23,000 or OBO.
Located in Stonewall LA, just south of Shreveport LA.
2010 built buggy.
Buggy info:
16 gallon fuel cell
HID head lights
Corbeau seats (New)
Warn 9.0 RC
Magnaflow muffler
Rigid 40" light bar
Spares:
Spare skins
$23,000 or OBO.
