Sold/Expired Suzuki Samurai 1.6 16v Swap
XtremeZuksOffroad
Tampa,FL
I have a complete 98 OBD2 1.6 16v for a Suzuki Samurai, I bought the 4 door Tracker running but was a rollover, the engine has 70k miles on it and compression was 190psi in every cylinder, we put a brand new water pump, oil pump, timing belt, timing tensioner, timing cover, all seals and gaskets, the swap will come with 1.6 starter and alternator, modified wiring harness, ecm, maf, breather system, adapter plate, XZO stage 3 clutch, heavy duty motor mounts, stainless steel header, this swap will come with everything you need to install it in your Samurai correctly. $3500
The second pictures shows the stainless header you will get with it.
