D-nAsTy-MaX
i have a 2001' toyota tacoma single cab rock crawler truggy full tube chassis complete with cab, full front clip, grille, lights, and interior minus seats only,.... complete setup... chassis has front and rear 4 link mounts (with misallignment) built in, has front dimple died winchplate mount with dring shackle mounts built in, front stinger bumper, has rear dimple died fuel cell plate mount built in as well as dimple died cooler/storage box plate built in which also has a winchplate built under it for a rear suckdown suspension winch,.also the 4link mounts are dimple died as well, and has built in rear shock towers complete with bungs ready to mount shocks which are also dimple died. so alot of custom dimple die work, all tube is d.o.m. tubeing, and the sliders are thick wall rectangle tubing fully welded, this chassis was professionally built right extremely nice will have to see to appreciate, it was built primered and unfinished due to no funds for components to complete build. has fully built d.o.m. interior cage as well that matches exteriror cage idenetical and is built as tight to cab as possible for full cab room for driver passenger, took the time to notch dash so that pillar cage tubes could follow down windshield pillar to floor not back in driver legroom in front of dash like most...
this chassis is a complete chassis just add drivetrain(motor, trans, transfercase, axles drivelines, links and shocks, fuel cell, tires/wheels, winches, and seats)
CHASSIS ONLY:
$2000.00 or best offer
NEW DEAL OFFER: $2500.00 or best offer will includethe parts i've gathered: 03' tacoma 32,000 mile 2.7liter 3rz engine complete and perfect engine, 84' toyota 4x4 pickup rear axle all factory toyota 8" factory 4.10 gears pulled from a good running truck i had no issues(complete lug nuts to lug nuts) as well as the complete factory transfercase from same truck perfect as well.
-all that would then be needed is:
-80's toyota g52 5speed transmission
-96-04' tacoma 2.7l trucks bellhousing/clutch (this allows you to bolt up 80's g52 5speed to the 2.7l tacoma motor so you can use 80's pickup transfercase and/or dualcases and 80's pickup yota 8" front solid axle)
-85' and under pickup/4runner 4x4 toyota 8" solid front axle
-then all the odds/ends to complete truggy(fuelcell, winch, drivelines(could use modified factory 80's pickup drivelines), seats, wheels/tires
call/text only: 828-506-6070
thanks,
kevin
CHASSIS ONLY:
thanks,
kevin
That is a nice start for 2500 bucks!
