Th350 shifter
Purged1978
Have a th350 with a b&m shifter in my yota crawler, I'm to the point that I can't stand that type shifter anymore! What can I change it too that would work better?
Which B&M shifter do you have? I'm running a Hurst Quarter stick on my TH350 RMVB and have no problem with it.
I'm not for sure, it was in it when I bought it, it's got the T you have to pull up on and it's pretty aggravating when I get in a spot and have to go from low to reverse
Yeah, those are ****. Get you a B&M Pro Stick and disable the reverse lockout and grind the gates. Or a Art Carr/Winters and cut the gates. I've used both and like both setups.
