Sold/Expired TH350 to 205 adapter
jmf
I need the adapter to go from th350 to np205. Also need the sleeve that goes from 10 spline to 27 spline. I swapping from the 4 spd to auto.
don't think your going to be able to do what your wanting to do. a stock 350/205 adapter with require a 350-205(27 spline female) case. if your dead set on using the 4speed 10 spline case, call ryan in morrison. he can build the adapter and the custom spline sleeve your wanting.
Do you have his number? Looking around online I think it can be done. Maybe not cost effective unless somebody has a used one. I'm all new to this and welcome any help or advice. Thanks.
Could the input gear on the transfer be changed? I know on my 241 I looked at swapping the inputs, seems like it was about $80 for the new input
Sent from my iPad using Tapatalk
You can get the sleeve and adapter from Summit Racing. They're from advance adapters but are a little cheaper. I just got the aluminum adapter from them. They had it in stock and it got here the next day.
