RogueFab
The BRUTE winch mount kit is the strongest portable hitch receiver mounted winch carrier on the market. Like other mounts, the main tube is 2x2x.250 steel box tube. We also have a 1/4 inch thick 50 KSI steel base plate. What really sets this beefy mount apart are the high strength 3/8 inch thick stingers that go outside the hitch receiver. This superior design is stronger for side loading than solid 2x2 steel bar!
The unwelded version is shipped as a weld together Kit. Add $49 for our BRUTE welding service to have us weld it for you and paint it with Hammered finish paint.
The front and rear wiring includes enough 2AWG copper wire to take both power leads to your battery from the front and rear bumper on any vehicle, including your quad cab longbed one ton. Includes 3 Anderson connectors, power interrupt relay, dash switch and wiring, and battery terminal connections.
Like all our products, this kit comes with everything you need. We include the high strength long hitch pin to secure this to your vehicle. We include the authentic Anderson brand connectors for the power leads.
Carrier only $119
Carrier with front wiring $199
Carrier with front and rear wiring $299
Front and rear wiring kit $199
MADE IN THE USA
Click here to see the BRUTE winch mounts on our webpage
Carrier only $119
MADE IN THE USA
