Rock Crawling Forums
tire burping with beadlocks
Reply to thread
Message
<blockquote data-quote="greenlion" data-source="post: 330612" data-attributes="member: 1675"><p>The problem is the inner bead of the bogger is wide enough to sit on top of the inner bead retention "bump" of the wheel. I had this problem with boggers on single beadlocks. I fixed it by measuring the bead thickness and then welding a piece of 1/8" round rod around the wheel just inside of where the bead sits. On my rims this ended up being just on the outside edge of the bead that was there. I just stitch welded the rod on but then had to go back and silicone the gaps so air wouldn't go by when mounting the tire. This absolutely keeps the tires on. In fact we have to drive the dmax over them now to break the inner bead down.</p></blockquote><p></p>
[QUOTE="greenlion, post: 330612, member: 1675"] The problem is the inner bead of the bogger is wide enough to sit on top of the inner bead retention "bump" of the wheel. I had this problem with boggers on single beadlocks. I fixed it by measuring the bead thickness and then welding a piece of 1/8" round rod around the wheel just inside of where the bead sits. On my rims this ended up being just on the outside edge of the bead that was there. I just stitch welded the rod on but then had to go back and silicone the gaps so air wouldn't go by when mounting the tire. This absolutely keeps the tires on. In fact we have to drive the dmax over them now to break the inner bead down. [/QUOTE]
Verification
Post reply
B
Latest: Bebop
Yesterday at 7:19 PM
P
YouTube of the day
Latest: paradisepwoffrd
Monday at 8:21 AM
Cash LeCroy Illness
Sunday at 2:58 PM
Saturday at 3:52 PM
Latest: Piros 1
Saturday at 2:27 PM
