For Sale or Trade for the Items Listed Below
TJ Buggy & Parts For Sale
2004 Jeep TJ Rubicon Dana 44
Disc Brakes
Detroit Locker
New Yukon 4.88 Gear Set
Yukon 30 Spline 4340 Chromoly Axle Shafts ($1,100)
Yukon 1310 Super Joints ($400)
Motive Gear Axle Tube Seals
Alloy USA Ball Joints
Nitro Axle Tube Sleeves
Gusseted Inner C's
Trussed
Stainless Steel Brake Lines
Drive Flanges
5 on 4 ½" Pattern
All Steering Linkage
Ready to Go Under 1997 to 2006 TJ of LJ
Set up for Hydraulic Assist (Complete System Also Available)
Asking $2,500 obo or Trade (Listed Items Only Please)
1998 Ford Explorer 8.8
Yukon Grissly Locker
Yukon 31 Spline Chromoly Axle Shafts
New Disc Brakes
Drive Flanges
Trussed
5 on 4 ½" Pattern
Asking $1,800 obo or Trade (Listed Items Only Please)
Ultimate Adventure Proven - Lightweight, Super Nimble, Agile & Crazy Fun
TJ Buggy Chassis & Tub w/Florida ***le, Full Roll Cage Tied to the Frame, Grill Hoop & Stinger, 3/16" Steel Body Panels, Rock Sliders, Full Metal Roof, Triangulated Front Four Link, Modified Rear Four Link, Super Flexy, New Currie 4" Progressive Rate Springs, Custom Spring Mounts, JKS ACOS (Adjustable Coil Spacers) & Bump Stops, New Limited Straps, New Rancho RS9000XL Shocks 36" Rear & 30" Front , Fabricated Metal Dash w/ Factory Gauge Cluster, Lightened TJ Hood, Radiator, Grill, Headlights, Blinkers, Fuel Tank, All Links, No Sway Bars - Add Your Engine, Tranny, T Case, Differentials and Your Done, Ready to Wheel or Purchase with Axles
Measurements
Ground to Belly 23"
Roll Cage Highest Point 79"
Wheel Base 98.5"
Total Weight 3605 lbs
Front Weight 1039/1068=2106 lbs
Rear Weight 751/748=1509 lbs
Left / Right 1789/1817 lbs
Front Track 78"
Rear Track 80"
Total Length w/ Stinger 148"
Total Length w/o Stinger 138"
Pricing or (Trade - See List Below)
$2,900 Wheel & Tires
$4,000 Chassis
$7,000 with Differentials
$9,500 with 4 BGF Red Label Sticky 37 x 13.50 x 17" & SpyderLock Aluminum Beadlocks
$14,900 Complete Turn Key Buggy w/2.5L, 5 Speed & Atlas 5.0, AGR Super Steering Pump & Hydraulic Assist Steering System, Driveshafts, Optima Yellow Top Battery, 9,500Lb Winch (No Line), Bucket Seats & New 5 Point Cam-Lock Harnesses, Hand Throttle
I will not split up in any other configuration than listed
As A Florida ***led Vehicle It Can Be Street Driven (with required Equipment)
Will Deliver Within 400 Mile or 7 Hours of Mount Dora, Florida 32757 at
NO CHARGE with a Non-Refundable $2,500 Deposit (Cash, Wire Transfer, USPS Money Order or PayPal + 4%
Please Email: [email protected] with any additional questions
Located in Mount Dora, Florida 32757
Runs and Shifts Smoothly
Thank You
WILL TRADE - Trade Items Considered:
- Clean 2003 to 2006 Jeep TJ or LJ, Rubicon & Auto Preferred
- Clean 2007 to 2012 Jeep JK 2 Door, Rubicon & Auto Preferred (I can do =/+/- Cash)
- Jeep TJ or LJ 1 Ton Builds
- Crawler
- Buggy
Clean Differentials From Known Professional Builders (No Junk, No Duallies)
- Dana 60 Front Driver Drop or Rear Full Width, Professionally Built, Excellent Welds (No Junk)
- Dana 70 Front Driver or Rear Full Width, Professionally Built, Excellent Welds (No Junk)
- Dana 80 Front Driver Drop or Rear Full Width, Professionally Built, Excellent Welds (No Junk
- Ford 9" Modular Housing Front Driver Drop or Rear, Full Width, Pro Built, Excellent Welds
- Atlas 2 Speed Transfer Case 3.8, 4.3 5.0
- Atlas 4 Speed Transfer Case 5.44
- Complete Running Low Mileage LS Motor, 5.3, 5.7, 6.0, 6.2 With Computer & Wiring Harness
NO QUESTIONS HERE - Please Email: [email protected]
Reasonable OFFERS Considered
Disc Brakes
Detroit Locker
Gusseted Inner C's
Trussed
Drive Flanges
5 on 4 ½" Pattern
New Disc Brakes
Drive Flanges
Trussed
5 on 4 ½" Pattern
Measurements
Ground to Belly 23"
Wheel Base 98.5"
Front Track 78"
Rear Track 80"
$4,000 Chassis
Thank You
- Crawler
- Buggy
