Sold/Expired tj linked coilovers red labels
beanlooge
Member
1998 Tj with ***le
Motor 4.0 around 70,000 on it and transmission
Transmission: ax15 with hand throttle
Transfer case: Atlas 3:8 32 spline shafts clocked flat
Front axle:Ford hp dana 60 kingpin with arb locker 5.13 35 spline cromoly inner outer drive flanges yukon super joints 5 on 5.5 lug conversion chevy knuckles disc brakes artec truss thick diff cover that also bolts to truss high steer arms all bearings and seals replaced have two trips on them
Rear axle:Solid axle industries high pinion 60 with 5.13 disc brakes arb locker 5 on 5.5 conversation
Suspension four linked front with fox coil overs with reservoirs professionally tuned and valved tuned by Wayne Israelson
Rear suspension four linked ome coil springs fox shocks with reservoirs also valved and tuned
Steering full hydro psc double ended ram
Jeep is flat bellyed,full 1.5 Dom cage with aluminum roof,rear cnc cutting brakes,rci aluminum fuel cell, aluminum rear crush corners,corbeau seats,crow harnesses, beadlocks with 39 red labels 9500 Ramsey winch with rope,griffen aluminum radiator,steel braided brake lines,tom woods drive shafts two piece front, 1.88 wall dom rock slider,tube fenders, grille hoop, tons of spare parts I know I'm missing stuff
Location pittsburgh pa
19,000 obo no trades
