blacksheep10
XBJRA champ/ 555 and team Nasty codriver
I'm doing a rubi and putting tons under it with an all new suspension
The TJ 03 rubi 44's and locker pumps/switches etc are for sale, $2500. Rear has Alloy USA shafts in it, the front has stock shafts in it, never have broken one but there is a full set of spares anyway in case. HD diff covers, wheel spacers included. The rear coil buckets have been cut off by new ones are on the floor from TNT. On the front, the track bar bracket has been removed as there is a 3 link bracket with the long arm kit. Wouldn't be too hard to put one back on off your 30, or I can put tabs on it if you just want the axles and not the arm kit.
The long arm kit has been stretched 6" in the rear and has the front stretch arm kit and front stretch arms. ($1300 upgrade). The whole long arm kit and all associated skids/stretches, brackets for steering relocation, spring buckets, etc all cost $3729 and have never been used. Asking $2500
http://www.tntcustoms.com/jeep_tj/rock-tek_long_arm_upgrade.aspx?variation=978
TSL SX's on beadlocks for these axles available for $1500, brand new, still have ***s, 15" single bead locks, anti coning rings, 36" tires.
Not pictured are the frame ends, buckets for front and rear, sway bar kit that can be locked and unlocked, shock towers etc. This thing is COMPLETE
