355/350/203
propane
custom cage
38" TSLs uncut
14 bolt rear
gm 10 bolt front
both locked
2 propane tanks
hydraulic steering
starts and runs
clean ***le
can be streetable
needs::::
drive shafts installed have them
steering lines installed have them
cage welded up
rear coil overs installed have them
brake lines hooked up
rear 4 link bars mounts drilled for correct bolts
front suspension i have coil springs for it
call or txt if you have any other questions
7083051688
3500$
propane
custom cage
38" TSLs uncut
14 bolt rear
gm 10 bolt front
both locked
2 propane tanks
hydraulic steering
starts and runs
clean ***le
can be streetable
needs::::
cage welded up
7083051688
3500$
