Sold/Expired Tools!! CNC plasma table, drill press, tig welder
Jduck
151
Athens, GA
4x8 torchmate 2 bolt together table (aluminum frame)
blue screen AVHC
Water table
Thermal dynamics cut master 151 plasma cutter (rated 1/2" production, can cut 1.5" thick)
Router package with 2.25hp dewalt router
Torchmate cad with tons of files included (no computer but can copy files over)
Bobcad software for 3d routing (license will need to be transferred with bobcad)
$15,500
pic after building water table
Jet ghd 20pf drill press/mill
3ph motor
power feed head
comes with HF slide table vice that needs to be mounted.
will need new chuck if doing any kind of precision work.
link to one on amazon http://www.amazon.com/354024-GHD-20PF-20-Inch-Geared-Powerfeed/dp/B0007M6GFO
$1100
Synchrowave 250 tig welder. It is an 88 model, I believe the foot pedal is bad (but haven't had anyone check it out) when you turn the machine on it tries to start welding. Pedal still controls amperage while welding, and machine can be used like it is, but will not stop arcing. Comes with air cooled torch, liquid cooled torch (no cooler though), foot pedal, misc filler rods, 125cfm bottle that is 1/2 full.
$1400
Re: Tools!! CNC plasma table, cold saw, drill press
Pretty motivated to sell since I'm moving and the new place doesn't have anywhere to set this stuff up.
Re: Re: Tools!! CNC plasma table, cold saw, drill press
Say what?
Sent from my DROIDX using Tapatalk 2
adjusted prices.
How old is the torch mate . How much run time
09, uses the USB hook up and not the old style serial cable. No idea on run time. I use it on the weekends/evenings.
Will also sell without the plasma cutter if you have or want to use a different cutter.
Any serious offers?
i sent you a pm regarding the cold saw
Cold saw is sold
