Sold/Expired Toyota buggy for sale
Rohlingoffroad
HC Supporter
Muscle shoals,Alabama
Started out as a 91 Toyota truck I built this thing to go wheelin and come home and not have to work on it
Front and rear axles are trail-gear rock assaults housings it has 4:88s front and rear
Front axle=
Trail-gears
Full hydo steering and three link kit
High pinion 3rd with detroit locker
Six shooter steering and arp studs
Arp hub studs
Longfields axle shafts and hub gears
V-6 brakes and vented rotors
Rear axle =
Trail- gear rear chromo axle shafts
Trail- gear three link kit
3rd member with Yukon spool
Disc brake kit
Tranfer cases =
Front case has stock gears
Rear case has Longfield output shaft and 4.70 kit from trail-gear with there adapter joining them
Transmission is a w-56 with trail-gear ceramic clutch
Drive shafts are 1 3/8 solid square stock from agri equipment with 11in of slip
Corbeau seats
rci fuel cell and msd fuel pump
Engine is a 22re built head shaved with a comp cam and balanced bottom end and has a Doug thorley Tri y header and msd coil
4-2.0 race runner air shocks
Tires are 38.5 /15 boggers on custom beadlocks
And I have a pile of spare parts that are going with it like
Set of new in box chromo axles
Manual hubs and brakes
Wiring harness and computer
Spare drive shafts and 4 3rd members and a lot more this rig is located in muscle shoals my numbers is 256-810-5008 askin 11,500 obo
Here is a couple of photos that I had. I will add somemore and a video. This is one tough rig will hang with most if not all one ton rigs out there.
Thanks for getting pics and videos up only reason I am sellin this is I bought a one seater buggy I don't have room in my shop for both of them
