ROCKRAWL
This truck needs nothing, its ready to ride!
Heres the specs;
$6000
865-898-5233
Drive train
22RE 4cylinder with 5 speed
Allpro straight axle conversion
4:71 creeper kit in transfer case
Allpro trans parking brake kit
LC engineering torq fly wheel and clutch kit
Bud Built skid plate and trans mount
LC engineering highflow fuel pump
Front axle
83 model front straight axle housing with 2 inch wheel spacers
Detroit locker
Full longfield Super Axle kit 30 spline
5:29 ring and pinion Cryo treated by Longfield Super Axles
Tom Woods custom front drive shaft
Axle seal kit from Marlin Crawler
Diff armor
Allpro high steer kit
Trail gear hydro assit kit " New Not installed "
Rear Axle
92 rear axle housing with 1 inch wheel spacers
Rear spool
Custom rear drive shaft
Full rear truss with trac bar
Diff armor
Suspension
Allpro straight axle swap kit
Front 5 inch Allpro springs
Rear 5 inch Allpro 56" long travel springs
Front 12' Bilstein 5150 shocks with allpro shock hoops
Rear 16' Fox adjustable reservoir shocks
Chassis and Protection
Font custom winch bumper
8000 lbs winch
Synthetic winch rope
Rock bars
Custom full inside cab cage
Rear flat bed with roll cage
Corbeau Baja SS seats with 4 point harnesses
Full doors with woking glass
Tube doors
15 Gallon fuel cell
Tires and Wheels
15 x 10 Allied bead locks " Black " x 5
37 X 12.50 Iroc's 1/2 tread x 5
Spare tire has a small hole but can be fixed .
No plugs or tubes in any tires !
Dual battery setup
Have lots of spare parts !
Extra transfer case
2 sets of extra stock birfields
2 sets of stock hubs
1 set of Mile Marker hubs" New in box "
AC does work and is very cold
extra late model calipers
Viair air tank
Highlift jack
IPF rock lights
CD player works
AMP 100 watt Alpine
Lots of bolts, belts,hoses,and anything else Toyota
Heres the specs;
$6000
865-898-5233
Drive train
Front axle
Detroit locker
Diff armor
Rear Axle
Rear spool
Diff armor
Suspension
8000 lbs winch
Rock bars
Tube doors
15 Gallon fuel cell
Tires and Wheels
Dual battery setup
Extra transfer case
Viair air tank
Highlift jack
IPF rock lights
CD player works
AMP 100 watt Alpine
