stuftmunky2k
Toyota crawler have had for around 5 years and just don't get down south enough to justify keeping it. Specs are as follows.
Built Turbo 22r on propane. (Mild cam, head work, hypertectic pistons, crane ignition, .60 over.) Motor has maybe 12 rides on it
Turbo and propane from Cary at got propane running around 12 pounds of boost.
Brand new electric fan, psc pump and resi, and tranny fan with 0 rides on them
Aw4 with ra designs shifter with 3 rides on it
Atlas 4 speed with 3.8 gears with 3 rides on it
14'' ORIS with 3 rides on them
4 link front and back
front axle is Trailgear yota housing, six shooter knuckles, drive flanges, hi pinion 3rd with 5.29 and Detroit, double ended ram, rcvs with og longs as spares.
Rear axle has disc brakes yukon gears and spool to match front.
Suspension seats have 3 rides on them.
40'' stickie treps on walker even double bead locks with 1 spare stickie trep.
Buggy is a crawling machine and flat out gets it. Its a hard choice to list it but time to move onto other adventures. I have a cucv 60 front, new 60 super joints, new 60 drive flanges, new high steer arms with knuckle bolts, front and rear fabricated 9'' housings that could be worked in the deal for extra money
Buggy is located in central ohio and asking $15k call or txt 937-243-2925 i don't get on here that much anymore. trades depends on what you have maybe a razor 1k, fast street car, or rat rod from 20s-30s
