Sold/Expired toyota driveshaft parts
billstoy
36
looking for parts near ringgold or AOP just looking to build some shafts . need both ends. shafts can be bent or broke. let me know what you have.
i've got a bunch of LC slip yokes $25 each......... and the nice thing about them if you are running a mini-truck shaft is this is a quick upgrade you can make on one end of your d-shaft to a bigger u-joint. The spine count and diameter is the same, all you have to do is pull your pinion or t-case flange off and redrill it to the LC pattern.
i've got 2 or 3 cv ends. i cut off, I don't run them.
billstoy this is all I have as far as drive shaft parts, I thought I had
the female spline ends but I must have sold them, the blue shaft
is 1/4 wall thick.
i have a bunch too
