Toyota help
hotshot
I know that there is several ways to modify steering on a yota truck. But, what is the best way? Brill and tap the factory pump, install a chevy pump, hydraulic assist and then you got full hydraulic. Which way would be the best? I'm still running yota running gear with 36" iroks!!!!! Ideas!!!
Depends on what you want to spend. You can run assist off of the factory pump for about $250 if you drill and tap your steering box yourself. Remove the restrictor in the factory pump and get a bigger reservoir. Never had any complaints out of that setup. Other than that, if you're going to replace pumps etc just go full hydro.
