Rjhoward32006
Selling this because i figured someone might want the disc conversion. It can be removed and installed on a wide rear if wanted. Brackets are bolted on not welded.
Narrow rear housing (no 3rd member) used solid front axle rotors and calipers so all 4 brakes are matching parts. Can remove parts and sell just the brake set-up if you dont want the housing or shafts. Located in cartersville/dallas area. Work in atlanta. Post up or text Jesse @ 678-451-2794 $150obo
Will trade partial on a bare wide rear housing.
If you were to buy the parts to do this swap without core parts it would run you about $250 after getting all the new wheel studs, bolts, etc...
Brackets
Brackets
