Sold/Expired toyota partout/cleanout
Rjhoward32006
Cartersville G.A.
call or text Jesse 678-451-2794. located in taylorsville ga. work in atlanta. can ship smaller items on buyers dime
will try and respond asap. work midnights so i sleep during the day.
parting out a 1986 sas ext cab toyota. was a running driving truck motor just had a knock.
buy the whole lot and have a nice truck plus spare parts for $3,000.
PRICES ARE OBO. If you dont ask i cant say yes/no
tried to price everything reasonably so dont low ball the hell out of it.
22re with bottom end knock. still ran. Complete with all acc. except for exh manifold. will include wiring harness, msd coil, air flow meter, igniter, ecu, and fuel tank (needs fuel pump) they had one ran inline.
This will make someones life easy to do a efi swap. $250
w56 trans 5 speed $175
Dual cases $400 or buy the cases, twin stick, mounts, and skid for $600
twin stick $100
Bomb proof case mounts x2 $100
budbuilt dual case crossmember $150
Axles front and rear. they are currently taken apart. can leave them apart for you to inspect or assemble them. $800
front= trussed, diff guard, 5:29, ratchet locker, marlin inner axle seals, vented rotors, 4 piston calipers, arp studs, high steer, factory axles
rear= ifs width rear, factory axles, 5:29, spool, diff protector, rotated spring plates, have a traction bar bracket i can include.
1.5" spacers and lug nuts 50
2" spacers 50
bilsteins (4 total) 12" travel 200
bilsteins (2 total) 14" travel one has a broke shaft needs replaced 40.00
4" trailGear front springs 150
5" TrailGear rear springs 150
22re header with exhaust, cat, muffler 100
driveshafts for dual cases front and rear. fits ext cab short bed 100
tapped ifs box and single ended ram 250
38.5 14.50 15 tsl steel belted and 15x10 wheels. chrome painted black tires are low tread could groove three for offroad use. 4th is toast 150
1986 cab and matching bed, all good glass, fenders, header panel, etc... has split window doors and bedliner across bottom. fenders bent, cab dented under drivers ext cab window 300
extended braided brake lines front and rear. one spare front and rear so three fronts and two rear 75
5.29 ring and pinion carrier and third. bearings and flange. will need locker, spool, or spider gears and side adjusters 150
3.5" fender flares 100
tg greasable shackles (4 total) 5" bolt hole to bolt hole 150
u bolt flip kit front and rear 75
1986 frame sas with tg shock hoop front and rear, square rock sliders 200
bare front axle housing small diff guard 50
misc rear axle shafts with drum brakes just ask 25 a piece
front axle truss was tacked on 10
knuckles L&R with arp studs 100
solid axle non vented rotor and hub x2 50
top shift case torn apart. was in good condition 50
stock 22re radiator 25
flex a lite radiator fan 25
stock power steering res 10
brake booster 10
brake master cyl 10
clutch master and slave 20
square port maybe 20r intake carb and acc 25
tan doors 1 cut down for 1/2 doors. just need to be finished 40
stock 1985 toyota tan wheels solid center like 7 or 7.5 in wide 15" 50 for set of 4
bench seat, good for a seat frame or camp chair lol 10
bully aluminum single steps 10
22r fan blade 10
thanks for looking!!!!
I am interested in buying the whole setup so give me a call. 706 741 5956
