Midtntoyota
Member
- Joined
- Jun 17, 2013
- Messages
- 11
- Reaction score
- 0
Arb air locker with 5.29 Yukon gear. Used but in great shape. Ready to drop,in complete 3rd member......500$. Via air compressor and switches 75$
Detroit locker used 250$
Spool with 4.88 gear. Ready to drop in. 300$
2 new sets of longfield axle shafts. Installed and removed never ran...... 600$ each set
New 5.29 Yukon gear. 100$
4 16" fox 2.0 air shocks need seal kits. 100$ each or 300 for all 4.
2 18" fox 2.0 air shocks ready to bolt on 425$
2 corbeau Baja SS seats. One has come apart at seam 230$
Toyota tube chassis. Built for rear engine and flipped axles,looks good. Have links and housings. 4 wheels steer parts as well. 1500$
18 qa1 3/4x3/4 heims. 275$
15x12 Mrw wheels with weld on bead locks..6 lug 275$
2 44x19.5x15 boggers 75% tread. Little rash On 15x10 8 lug wheels 600$
2 double ended rams with mount for Toyota axle. 230$ each
6 gun knuckles hubs n rotors included. 250$
High steer arms with hubs n knuckles. 150$
21 spline marlin crawler doubler with 4.7 trail gear set up in rear case 750$
4 cylinder transmission with new clutch. 200$
22r engine. Complete minus carb 10k miles on stock rebuild....600$
Chevy 4speed and 208 transfer. Slip yoke rear 150$
73-87 Chevy front springs 6" lift. 100$
Easiest to [email protected]. Located right outside Nashville. Everything is apart for inspection. This is a Buggy I was building and decided not to complete.
