Sold/Expired Toyota Rock Buggy
rogermaginel
New Member
Toyota Rock Buggy based on a 1990 Toyota standard cab long bed pick-up. The motor is a remanufactured 22RE with less than 5000 miles. It has been converted to run on propane. The axles are from a Chevy military truck with a 10 Bolt front and a 14 Bolt semi-floater in the rear. Axle gears are 4:11 with a posi in front and welded gears in the rear. The front suspension has 52 inch Chevy springs and the rear is a Trail Gear 4 link suspension with 16 inch Fox air shocks. Filthy Motor Sport 40 inch limiting straps keep things in check. There is a 1500 lb winch in back to suck down the shocks when needed. Up front there is a 6000 lb winch, just in case. Tires are 37 inch Super Swampers (brand new IRoks 37X14.5X15 on the rear and TSL 37X13.5X15 on the front) mounted on 15 X 10 steel wheels. Lots of other cool stuff is a BTF battery box, Optima Red Top battery, Redneck Ram Hydro-assist steering with remote reservoir, LED taillights, night time lights front and rear for that night run that is so much fun, 3R Racing Seats, Chevy 1 ton master cylinder with disc brakes front and rear, Low Range Off Road Bomb Proof motor mounts, Reid flat top knuckle for high steer cross over steering, BTF Kryptonite diff covers front and rear, G-Force seat belts, Low Range Offroad Rock Sliders, Bud Built transfer case and transmission skid plate, dual propane tanks (set up for single right now), four small pelican case storage boxes, and extra axles and hubs for the 10 bolt. This is a very capable, light weight, and fun buggy. It's not done (never will be if you are into building your own ride) but it's a turnkey driver/crawler as it is. You never get back what you put into a project like this and I understand that. With all that said the selling price is $7450. Medical reasons and starting another project is the reason I'm selling. Call 850-803-89 two six if you're interested. Ask for Roger. Thanks for looking.
Pics:
