Rjhoward32006
Bolt on toyota tube bed. Was on a 85 ext cab short bed truck.
1.5" .120 wall hrew
Spare tire mount bolts on and is removable. Hi-lift mount on drivers side.
Bed comes with bolts needed, tailights, and fuel filler neck/hoses.
DOES NOT come with toolbox or tire. I have the sheetmetal for the front panel.
I can attach it or leave it off so you can paint it, either way.
Home made not professional but gets the job done
$500 firm jesse 678-451-2794 Taylorsville Ga work in Atlanta.
Toyota bolt on winch bumper. Home made, gets the job done.
Made out of 1/4 and 3/16 plate
Bumper only, winch and led's not for sale.
$150 firm jesse 678-451-2794 Taylorsville Ga work in Atlanta
Have 4 crawler style wheels. 6 on 5.5 9" wide 3.75" backspace
4 toyota stock wheels. 6 on 5.5 7" wide 4" backspace
8 tires total. All 32 11.50 15's One is new, two have good tread, some are pretty used up. Two have cuts in sidewall and use tubes.
Some have a little dry rot, some are cupped uneven wear. All hold air fine.
Good offroad, trail, hunting tires. I do run some of them onroad but would not reccomend it. They are unbalanced.
$300 for everything. Not wanting to split up or dismount.
Jesse 678-451-2794 Taylorsville Ga work in Atlanta
1.5" .120 wall hrew
