Sold/Expired Toyota
Codrod23
88 Toyota pick up . Build from frame up . Turned out nice . The motor is 22re had 180000 when I pulled it out of truck and put in this one . Had new water pump timing chain and head on before pulling out . Truck drives good . $ 2000
Pic
1988 Toyota pickup w/87 22re
Had 180,??? When I removed it from my wrecked 87
Had new timing chain , water pump, and head at around 170,000.
All started my cousin wreaked my 87 truck so I bought a rolling 88 and I had a good frame so I went from there . I've been pulling parts here and there putting this truck back together ( not rigged ) frame has zero rust rot cab has some small dents here And there
.had alignment 2-6-13
.new batt 2-6-13
. Rebuild starter
.changed motor oil and front and rear diff
. 31 10.50 15 w/ rock rash and steel wheels ( not new )
. Set up with turn key then push button start
. Primed cab
Needs
Tail lights hooked up ( was going to put a regular bed on it and didn't want to cut into a good wiring harness .
. Front side bumpers ( see pics )
. Brakes are alittle soft ( "think I have it resolved"
.shifters have slop of course easy fix with shifter bushings
Inside
Is ok shape . Put new carpet In it from a 98 Tacoma
. Kinda dirty around dash (25 year old truck)
. Tach , speed o , clock works
. Puter market temp gauge . Need a oil pressure gauge ( don't trust the stock one . Hope this helps ill send pics later tonight thanks
Sent from my iPhone
Still IFS front ? stock gearing ?
