I have a set of Trail Gear rock assault axles
Rear, rock assault houseing, V6 third, spool 5.29s TG disk brake set up, Trussed and set for four link, has stock axles because one of the chromos is broke and on the other the splines are twisted.
Front is trail gear rock assault houseing, sixshooter knuckles, and highsteer arms Trunion bearing eliminator kit, High pinion with Detroit ,5.29s. trussed, Four linked, and set up for full hydro.' also set up for coil springs and shocks, could easily be modified.
Has TG dirty thirtys with TG drive flanges, and arp Studs. ( the Pass side birfield is busted and the inner shaft splines are stripped on that side. I dont think it got the detroit but am not Ceartin)
39.5/16.5/15 PBRs Tires have been cut like a atena cut TSL probly 65/70% on the Treads that are left. Wheels are 6 lug weld on Beadlocks not sure on back space. comes with 2in wheelspacers.
2500 OBO for the package, Im in Texarkana but willing to help with Delivery if Need be, Dont mind Driveing if you help with Fuel.
will Get pics asap
will Get pics asap
