XRR
Member
- Joined
- Sep 12, 2011
- Messages
- 21
We took time over the 4th to go through our Trail-Gear inventory. Below is what we have in stock and ready to ship or deliver. PM or email us @ [email protected] if your interested
Thank you for your time
XRR
P/N Description
110010-1-KIT Front Spring Hanger, Kit
140171-1-KIT Knuckle, Stud, Hex, ARP
120234-1-KIT Small Diff Armor
140325-1-KIT Trail Safe Inner Axle Seals (Pair)
111314-1-KIT Bushing Rear Leaf Spring
110046-1-KIT Shock Mount Kit, Pair
180190-KIT Weld On Flat Tab 9/16" Hole
120089-KIT Gusset, 3-Holes
180517-KIT LED Light - Clear
140059-1-KIT Solid Pinion Spacer Kit: 4 Cyl
110026-1-KIT Frame Tubes, Kit
140157-1-KIT 54mm Axle Socket
110042-1-KIT U-Bolt, Flip Kit, Front 79-83/Rear 80-95
140033-1-KIT Magnetic Drain Plug w/Aluminum Washer
140060-1-KIT Solid Pinion Spacer Kit: V6
100001-1-KIT Trail-Creeper Case 21 Spline Dual Case Adapter
140135-1 R&P, 5.29, 4cyl Trail-Creeper
140160-1 R&P, 4.88 4cyl Trail-Creeper
140035-1 Inner Axle Seal
111308-1-KIT Bolt, Greasable M 18x150mm
130020-1-KIT Pitman Arm, Flat
301076-KIT PS Pump Bracket Kit, 2.7L Tacoma
170004-KIT Knuckle Pull Scale
110043-1-KIT U-Bolt, Flip Kit, Front 84-85
110008-1-KIT Shackle Kit 5.5", Front Offset
140011-1-KIT Brake Line Kit (2 Front 1 Rear) 26" Long, DOT Approved
180156-1-KIT Taco SAS 3.4 Oil Pan Conversion Kit
100063-1-KIT Speedometer Extension Cable
130586-1-KIT Rod End FJ-80 Right Greasable
130587-1-KIT Rod end FJ-80 Left Greasable
140031-1 Differential Set Up Kit 4 Cyl.
XRR
P/N Description
