WideOpenDesign
Off-Road Parts Superstore
[size=10pt][size=10pt]TRAIL NECESSITIES[/size][/size]
There are lots of items you need to be prepared to hit the open trails! We have a wide variety of options for you to stock up your rig with trail gear! make WOD your one stop shop for trail necessities! For a list of all products check out the website, http://www.wideopendesign.com/
[size=10pt]Rock Recovery Straps[/size]
Our Rock Recovery™ Straps are made from 100% high-tenacity, polyester double ply webbing that is UV and abrasion resistant. The eyelets or loops are reinforced with an abrasion resistant material for maximum strength and durability. The load or tow rating on the 3” wide straps have a tow or load rating of 35,000 lbs.
[size=10pt]Axel Off Road Trail Helmet[/size]
High Impact ABS Shell with Soft and snug EVA liner 17 Vents?Removable and washable Pre-molded Interior Pads, Comfortable-Fit Design, Easy chin-strap Quality Standards: CE EN1078
[size=10pt]MaxOut 2.5lb Dry Chemical Fire Extinguisher[/size]
Twice the size and power of the smaller extinguishers, plus an "A" rating for extra peace of mind. These proven ABC fire extinguishers utilize a specially fluidized and siliconized mono ammonium phosphate dry chemical.
[size=10pt]PRP 2" Padded 5 Point Harness[/size]
This 2”, 5 point seat belt from PRP has sewn in pads for comfort, all black hardware for cool styling and quick adjusters on the shoulders. The new quick adjusters fix a problem that has been an issue with off road seat belts for years. Once a belt gets some dirt and water in the webbing they become very difficult to adjust, these new adjusters will always provide a quick easy to use seat belt.
