I have a 01 48k mi 5.3/4l60e.... going to have an atlas behind it.
I'm having second and third thoughts about running the 4l60. 3 main reasons = strength, cost to make it stronger, no RMVB.
So, been eyeballing th350/400.
I'm not a big HP guy so this motor is likely to stay stock+headers/tune for awhile. The most I could ever really see doing to it is a cam swap.
What has to be done to the th350 to make it reliable behind this little motor? I will run a FRMVB. rest of specs will be tube chassis <4k lbs, 60/14b 3.0/3.8 atlas and 5.38 gears f/r
Then of course i could just go with a 400 but do I need 400? it's bigger, heavier, uses more power.... but is definitely stronger.
Oh, and I'm going to do all the tranny work myself. Been inside 47re's/700r4's so I doubt I'd be surprised by anything in a th350/400
The old boy that built my 700 was a hardcore racer and had been building trannys since before there were automatics. No offense meant but maybe the problem is the builder and not the transmission. I do know the parts are a lot stouter in the later ones, maybe you've got an early production unit with the weak parts. My Willys is well over 4000lbx, and while I'm not a rockbouncer it has been beat on a few times in the last 15 years.
